Thanks for the info Miles. I've been thinking about this and you seem to have a lot of knowledge, so I'd like to run this past you. I'd like to put both the pedal crank sprocket and the motor-driven crank sprocket on freewheels. This is how I propose to do it, using a SickBikeParts crankset: I'll put the pedal sprocket on a freewheel adjacent to the right crank. Attached to that sprocket's backside (toward the bike's midline) would be a flanged male adapter threaded for a LH thread BMX freewheel 16t sprocket (readily available) that would be the motor-driven sprocket. I could bolt a larger sprocket to that if necessary, but I'm using a Unite 1016Z3 350w with built-in 9.8:1 reduction, so we're not talking a lot of power or rpms here. I'll have to have the flanged adapter fabricated, but even the other way I'd have to have a bushing fabricated, and the crank freewheel will save me having to pedal the motor chain. Using LH thread will have the BMX freewheel tightening onto the adapter on the pedal sprocket, which is of course the chain drive sprocket to the derailleur. I wonder if there will be room for the 2 freewheel/sprockets on SBP's 131.5 mm cartridge or if you see any other problems with this. I'm currently using this motor to power a front wheel drive through a 3-speed Sturmy-Archer hub with a 19 tooth sprocket and it works pretty well. Thanks for any advice - jd
