Miles said:
Thud said:
used to be you couldn't find a decent axial motor....now you can't swing a dead cat without hitting one!
It's not axial flux, though....
: http://translate.google.com/translate?u=http%3A%2F%2Fwww.sinusleistungssteller.de%2Fstand.html&sl=de&tl=en&hl=&ie=UTF-8 (scroll down)
Note the copper strip windings.......
Miles, if you follow that link you give, about one third of the way down you see a velomobile picture and another link above it labelled more. If you follow that link there is some very interesting data about the velomoblie efficiency, there is also a 10 minute video which includes a section where he is going 55kph up a 7% slope. Here is a little of the Google translation of that page:
After an initial inventory, a lengthy discussion and some preliminary experiments with possible components that were attached to an ergometer, we recommended not just our controllers SLS-42-110 also suitable for this application engine from Torcman. This is coupled with an additional clutch and a gearbox on the bottom bracket. To ensure that the engine is not supplying drive power when the crank rotates faster than the engine. The maximum speed of the engine, we can set the parameters for the SLS-42-110 accurately and precisely define it, to be effective at what maximum speed of their support. A second positive effect was achieved with the clutch: the start-up is possible only with muscle power, as the currently available SLS does not create any start-up from the state.
The battery was developed by Wulf Kraneis of 12 parallel strings with 10 series-connected (10S12P) Lithium-ion cylindrical cells, which by the elongated shape of the resulting battery packs are accommodated in elegant bike. With approximately 7kg keeps the weight of the battery pack still in the frame. The set point is about our speed control unit (SG), the potentiometer is mounted directly on the wheel and can be operated with the thumb.
We agreed to meet with us in 19/06/2009 Kist to incorporate the SLS into the waiting vehicle and make driving tests for the controllers first ballot.
Overall, the bicycle is placed on that day more than 35km test track in some very hilly terrain back at an average speed of about 50km / h. Were to consume less than 0.25 kWh of energy initially carried 1,0 kWh. If one high, there is considerable range of about 150km pro kWh! What proportion of the muscle while playing, but can only judge by the driver himself. To us, he has certainly made no impression exhausted - quite the contrary!
Again, coverage 150km/kWh! If we were a liter of diesel (energy content 10kWh) using a diesel engine and generator into electrical energy (converted, we assume an honest modest efficiency of 35% for it!) We would get 3.5 kWh of electricity. The Cycles could thus drive over 500km, this is over 5 times as far as the general Economical, which has the automobile industry ever produced (and also for testing purposes only!) and about 40 times as far as the average car today !
I'd also like a description of what makes this motor different if you can manage it. Thanks.
