Mfabricator
Hi all, I bought a gen2 Chevy volt module thats 2p 16s. Due to my bikes space limitations I have to remove from the housings and will not be using the chill plates. While restacking them and clamping the tabs I noticed that they are a little more puffy than I feel comfortable with. It seems if I give them compression of any amount I will be clamping air more than the core, this may be partially because I live at a little over 5000ft elevation. The cells are from a low mileage 2018 model and show no signs of any self discharge. How dangerously sinfull would it be to put a pinhole between the tabs in the expansion zone at the top, and then seal it up after compressing lightly and allowing gasses to escape? Also what gasses would they be? TIA for help and insight.
