A breather without leaks ...
Have found an easy way to modify the vent hole, to prevent any loss of cooling oil.
Cut about 1/2 inch length of the plasic tube that is sometimes used as extensions on aerosol can nozzles.
(It has about a 1mm bore and a 2mm OD.)
Use silicone gasket sealent to bond this into the angle vent hole (angle described by andynogo at the top of the previous page), so that it is almost flush with the outside surface of the hub, but protrudes inside the hub by about 5 or 6mm.
In my experience, this is sufficient to prevent any oil which is running down the inside of the cover, from leaking through the vent hole. But still allows the hub to breathe, preventing leakage through the axle seals, and thus avoiding oil contaminating the brake disc.
Burtie
Burtie
