onemorejoltwarden
I have a Hailong style battery 52v 17.5 aH from BafangUSADirect that needed a BMS replacement.
They were out and so I used a Vruzen 52v BMS.
The case apparently needs a thinner, slimmer BMS and the Vruzen BMS leaves the case about 12mm from closing.
Its power wires also come about 4-5mm up from the BMS and I would like them not to press on the case,
and the cell pack sensor wires are also much thicker interfering with the fit of the front of the case.
The case top rested on the battery retainer frame, holding it in place and made it very secure.
I'm not excited to start carving on the case, but I may need to put a "penthouse" for the BMS and
or furr it up internally.
Are these known to be ABS or other plastic?
I looked into the "whale" cases, but they have a different frame mount, which are not the same as this and my other batteries.
The notion of a frame bag and two different types of mount is, um, inelegant.
Any suggestions or similar experience?
ALSO,the new BMS lacks an On/off switch.
COULD I SWITCH THE TEMP SENSOR so that it would also be an On/off ?
If it was NC I could put a switch inline , if Normally Open I could use a switch to short it.
?GOOD or BAD idea?
?GOOD or BAD idea?
