Username1
- Joined
- Nov 26, 2013
- Messages
- 168
For people who don't live in hot climates, cold weather poses a big problem for batteries. One obvious solution is insulating the battery case and adding a heater for when it's cold out.
My question is would heavy insulation ever be a problem in hot weather? The cells produce some heat of their own. Adding insulation and a heating pad is easy, but also adding a system to extract heat would be much harder. It would have to involve either some kind of moving parts to open air vents, or liquid cooling with a radiator. This adds significant weight, size, complexity, points of failure etc.
I guess this could depend somewhat on the cells and application. I'm talking specifically about PEVs like e-bikes, e-scooters etc. They tend to have batteries from around 0.5-4 kWh and use 1-2c for their continuous discharge rating. I'm just trying to get a sense of whether a heavily insulated battery would ever face heat concerns in worst case scenarios, like going purely full throttle from full to empty on a hot summer day.
