todayican2
- Joined
- Apr 22, 2009
- Messages
- 139
Toying around with an idea, and I wonder if anyones seen something similar?
Building a lightweight trike to use a small (ish) electric motor. say an etek or mars to drive the vehicle at low speeds (and be geared accordingly) say to about 35 or 40.
Then have a direct drive small diesel running via a centrifugal clutch with just the one speed to take over above 35 or 40 to drive it to highway speeds driving the other side of the wheel on a separate sprocket.
One obvious problem, there may be others would be the electric motor "generating" when driven to a higher rpm in "highway mode"
a freewheel hub would cure this no?
Anyone seen one capable of this kind of use?
