tmho
Below is a link showing my geared hub motor is running with abnormal noise at certain speeds. (Please turn the sound volume to maximum in order to hear the noise clearly.) Since I do not have equipment to check the rpm of the motor, I only can use the ammeter of the power supply (at the lower left corner) to show the change in speed/rpm of the motor.
https://youtu.be/oTjsSqiQX9A
The abnormal noise starts at around 0.8A, but it disappear after around 1.6A. The set up in the video is just the rear wheel with hub motor installed onto the bike frame by tightening the axle nut to the rear drop out of the bike frame. The freewheel and the rotor of the rear disc brake have not been installed. The motor is not rubbing on anything which may be the cause of the noise.
I have problems with this motor for quite a while. https://endless-sphere.com/forums/viewtopic.php?f=3&t=78459 is my previous post on it. Now I find that the problem is just running with abnormal noise at certain speeds, so I would like create this new post to get help.
I suspect that this problem is similar to the problem in a car with unbalanced wheel, which the driver will feel vibration at certain speed. When I opened the motor the first time, I used a puller to pull the rotor of the motor out. I deformed it a little bit during the process. The center of gravity of the rotor is then not at the center, which will cause vibration when it rotates. At certain speed, the vibration resonates with the frame which makes the abnormal noise. Am I correct?
If my guess is right, then fixing the warped rotor of the motor is the way to fix the problem. I have tried fixing the rotor with a C-clamp as mentioned in my last post. But I could not get it back to shape, just a little better. Is there any suggestion on how to fix the warped rotor?
I have not tried the motor under load. Will it be possible that the noise go away when the motor is under load? It will take me quite a lot of time to hook up everything so as to test it under load. If it is not that possible, I do not want to waste time on trying that. However, I will still try it finally if there is no way to solve the problem.
Any other suggestion on how to fix this problem is highly appreciated.
