Hi,
SAIDIS is a DOS program used to adjust parameters on Simovert controllers. It communicates over the serial port. It was written back in the day and gets confused on more modern serial ports-probably because of the FIFO buffer that later serial ports use. I used to run it on old two old Win 98 computers but they both are gone.
I am trying to get it to work on a Windows 11 computer using vDOS, DOSBox 0.74-3, and DOSBox-X. I am using a USB to Serial adapter.
In each DOS, I can get SAIDIS running and saying in the SAIDIS window 'Connection OK' but then it tells me the data is incorrect. My conclusion is that the serial connection is working but I am having the FIFO problem.
Has anyone solved this problem? Does anyone know what communication protocol SAIDIS is using? My SAIDIS is 2.0. Does anyone have the 3.0 version?
Thanks
Cliff
Thanks
Cliff
