I know this has been discussed probably 100x on the forum but I can't seem to find anything about voltage high voltage sag and when you should stop using your lipo batteries.
With my new 45 amp controller, the voltage sag seems to be alot when going full throttle which I do quite often.
my 18s4p 20c 5000mah packs have a voltage sag of about 2+ volts on full throttle. This makes me unsure about when I should stop using my batteries.
should it be at 3.65 under the full throttle voltage? But with my extreme voltage sag that I seem to be getting I am not sure what is safe to optimize my battery life.
What voltage per cell can I safely do under full throttle?
What should I look at more closely when determining to stop using my battery, full throttle voltage, resting voltage, half voltage?
I have read posts on the forum where people stop using their batteries 3.7 under load. But if I did that, my batteries would have a resting voltage over 3.8. With a 4p setup that seems too high to stop using my ebike as I still have plenty of battery power left at this point.
My last rides with my new controller I have been ending my rides early because I am looking at the voltage under full load, only to drive all the way back home and still have close to 3.8 volts per cell.
