Do motor shafts have to be steel? All the motors I've seen have steel shafts. I got Astro 3210 & 3220 in mind, but this could apply to others also. Problem I'm seeing with cooling my 3210 is that heat transfer from inside the motor, to the outside is slow. Even if I get a heat sink to dissapate 5X's via surface area, I'm only looking at being able to apply an extra 5-10% additional amp(or power; uncertain which is more correct). I can put a glorious CPU heatsink on the exterior body.
A fast way to cool my little Astro3210 is to put an icecube on the protruding steel shaft. Then I see SDP-SI sells hollow steel shafts. Cool. Yet when grinding I notice that aluminum transfers heat around much faster than steel. (I'll edit later and back up several of these points). Aluminum should withstand 700f degrees, heat tolerant enough for the inside of an RC motor.
So, if aluminum doesn't mess up electrical fields, or something, and Astro says they can build motors with 12mm shafts, why not use 7075 aluminum rod? Could get it 12mm diameter and put a 4mm hole, maybe larger thru it. Then place some sort of mini fan blade at each end, presto, airflow to carry inner motor heat out and away
This isn't so hard and doesn't seem anyone else has done this. So what gives? Where I'm off
