This article has little to do with our E-bikes. We are talking about much more weight, and much more difference in weight, and in power too. Yet, the small numbers can give a good idea of the big ones.
There are different builds here, with a difference in weight over 150 pounds. There are some that run with 250w. and others above 15000w.
Let's say I am in the middle for power, seeing 7000w, but on the low side for weight with a tad above 230 pounds for rider and bike. That is a very powerfull ratio, and I would need much more power to keep the same performance level, if I was to ride at 350 pounds.
Then, there is the weight distribution factor. The difference of power needed to accelerate 10 extra pounds of tire and rim, is higher than if those 10 pounds were on the rider. The weight distribution also affects handling as well as geometry design.
It is not because our bikes are powered, that the weight factor is any less important in the design of our build. It is a major part of the equation, that we have to deal with.
Then, about the 40 degree climbing, I ride the stairs very often, and I believe that many here do it too. If wou want to know if your power to weight ratio is good, try climbing a series of 12 steps from 10 ft start.
