After reading tuna's post for his commuter; it provided a good basis for some of my questions; however i decided to start this new thread for any other newbies looking at the same thing and questions i couldn't find an answer to easily...
http://endless-sphere.com/forums/viewtopic.php?f=3&t=34224&p=497132&hilit=+future+proof+#p497132
I am looking for a commuter however it needs to keep up with traffic. A flat ride of 5km each way however needs to:
- Reach 30mph. Anything over is a bonus and dangerous riding through the city!
- Reliable w/ low maintenance as i am no electronic or bike guru.
From my research so far it looks like i will need at least the following parts
- Motor w/ rims
- Freewheel
- Torque Arm + 3mm washer
- Controller [Lyen's 12mosfet]
- Battery w/ charger
- Cycle Analyst and PAS
- 1/2 twist throttle
- 3 speed switch
- eBrake lever
- Tyres
- Triangle bag or rear rack
- DC-DC Converter
- Turn Key switch
- anything else?....
- Controller/Hall tester?
That's the easy part... now for the questions.
- Motor:
- Looking at the HS4065 w/ rims of 26x32mm wide. EMTB suggest this only handles 2.5kw continuously however what if i want to run 72v @40a in the future?
- Its been suggested that the HS4065 may be a pain to install and the LBS will hate me for it as it may or may not fit the bike properly?
- Tyres
- Hookworms 2.5" seems to be the tyre of choice. Does the front and back tyres need to somewhat match in width?
- Also put in some Mr Tuffy liners and heavy duty inner tube for extra potection and dont want to change any flats.
- Freewheel – I currently have a 9 speed on the bike
- If i move to 7spd freewheels means a change in derailers + chain. Yes?
- Is there any benefits from going down from 9 to 7? or to 8? Why would anyone switch?
- Is the freewheel only necessary due to the 11T?
- Has anyone ordered the 8 or 9 and found that it doesn't fit and must go to the 7spd?
- Battery Getting a triangle battery of 50V @12AH of EM3V. Believe it is a A123?
- I believe this is sufficent on the 4065 to get up to 30mph even with a controller of 25-30A?
- Getting something with more range - ire. @18AH is it just a waste of money if i only travel short distances and regularly charger battery?
- Cycle Analyst
- Has anyone bought the security screws so that users cannot tamper with the brackets? The bike will be locked outside.
- Charger
- Read that a charger drawing more A is not good for the battery as this will shorten the life of the battery...
- Is there any charger that can be limited in output (configurable) depending on your battery? (ie. if i update to a 72V battery, the charger is still okay?)
- DC-DC Converter
- Read this is only for up to 48V batteries? I know 50V is minor however do you have to modify the dc converter to purchase another?
- Wondered if anybody have another dc converter that allow drawing of more power (ie. up to 20A instead of the 2A)
- Locking
- Not too sure if its safe to leave the battery in the bag and leave the whole thing in the streets locked by a D lock.
- It looks like thieves can get to the bag and hence the battery etc... does everybody always take the battery with them if its stored in a triangle bag? (or as i've seen stored in pelican cases! or mod the frame to house the battery)
thanks in advance
- Motor w/ rims
- Freewheel
- 3 speed switch
- eBrake lever
- Tyres
- DC-DC Converter
- Turn Key switch
- Motor:
- Tyres
- Cycle Analyst
- Charger
- DC-DC Converter
- Locking
thanks in advance
