Hey Dudes,
Just got a 1000w hub motor shipped to me in two separate boxes (rotor in one box and covers in the other).
The side of the rotor that has the cable stick out of the axle needs to go into the bearing hole in the left cover,
only the problem is that it doesn't fit in the hole along with the axle!
I flattened the cable on the flat part of the axle and even greased the su**** so it will slide easily but it doesn't fit
in the bearing hole! it's too damn tight (that's what she said) and I almost damaged the cable's insulation.
Am I missing something? I hope you guys show me the kind of solution that goes like "you idiot, first put the xxxx
and only then put the xxxx"
Roy
Roy
