So, after a long time a HS3548 that I accidentally damaged venting years ago, has found it's way back to me.
I hooked it up and it still runs fine, as Philistine had mentioned to me, which is great but I wanted to be sure it would do more than just freewheel if I build a wheel onto it.
So I've opened it up, cleaned it out and carefully picked at and pried back the damaged windings:
It's a bit hard to see from the photo's but there are 5 broken wires total. 3 are on the loop to the right hand side and 2 are on the loop to the left.
As the windings are tightly wound, I can't just solder them back together as is as they don't meet close enough together for this.
I'm thinking I will have to use some 24awg silicone wire cut to (very short) length to join them all back up. I'll try and put some heatshrink on the joins, but I don't like my chances of it not shrinking when soldering given the short run.
Then, once done, I will put a bunch of epoxy in there to make sure nothing shorts or moves about.
Any thoughts from others? Has this been done before?
Cheers
Cheers
