I almost had to do a 15-mile walk of shame home from work a week and a half ago, when the clutch in the Fusin geared hub on DayGlo Avenger cracked open and wouldn't transfer power from motor to wheel. I found that after a mile I simply wasn't gonna be able to pedal it home, mostly because I use an "airless" solid tube on the rear wheel that is like 30PSI or less equivalent, adding so much rolling resistance drag on the heavy back end plus me as a rider that I coudln't put out enough power myself to keep going on the slight uphill (whcih is several miles long); my knees just hurt way too much--that's why I have the motors, really.
Fortunately I was able to fix the clutch with a radiator hose clamp temporarily, though ti was tearing up the inside of the hub casing side cover, coating the rest of the motor with aluminum dust and shavings.
But about half a mile from home I was forced to switch back to pedals only and then almost walking it, when the motor overheated from running ti too slow with the load on it, trying not to break the clutch repair.
Then a week after that, this past Friday morning, I really did have to do a three-mile-long hour-plus walk fo shame with CrazyBike2 because the rear tire blew out, tube and all, unpatchable (tube torn up and tangled in chain and freewheel, had to cut it out to even roll the bike). That super-sucked, and left my arms and hands going randomly numb for days (actually it is still happening sometimes), and my whole body still aches from pushing the bike that far.
Worst part was knowing that I could have prevented the whole thing by simply changing out the tire that I KNEW was going to pop any time now, but not having had the energy or time due to work and stress.
I had a spare tube with me but I simply couldn't handle the tools and whatnot to get the bike apart enough (and back together again afterward) to install it. Plus the tire was so torn up in two differnet places that I doubt the tube would've lasted 5 minutes even walkign teh bike.
Then after fixing that and some other things on the bike, on the first test ride the rear tube sprang a medium-slowish leak a couple miles into the three-mile test ride around the neighborhood, and I ended up walking home the last maybe 3/4 of a mile or less, because I didn't have a working pump with me.
Nowhere near as bad as the 3-mile walk, beause the tire had enough air in it to roll well, as long as my weight wasn't on it. Way less sucky than before, and shorter.
If I had moped tires/tubes/rims on the two bikes, I wouldn't likely have had either problem (because it'd've prevented the flat on CB2 both times, probably, and would've been high enough pressure or at least could be aired up to higher pressures on DGA).
