grimbasement
I have a 48 V 20 Ah ping pack that I bought last year that I puffed some cells on by running regen too soon on a fullish battery (It also could have been the balance wires had an issue which is why the last 4 pouches on each side puffed. or It could be I left the BMS connected for too long this past winter).
I finally decided to cut the bricks open see if I could salvage some of the pouches. Turns out 4 pouches (8 total) of the packs were puffed so I lost about 7 V. I cut off the puffies and remaining pouches are all balanced at 3.4 V and haven't been on a charger in a year so the remaining cells are good. I'm not interested in further breaking down the pack so I'll solder them together and combine the 2 packs into one for some extra range on some touring rides. Question is how can I handle the BMS? I have a few working Ping Signal Lab BMS hanging around but with 2 less cells how will balancing work? I think I have read that the Signal Lab BMS can be used with fewer than the number of cells but I'm wonder about how to keep the cells balanced long term can the Ping chargers do it or should i just plan on balancing with a single cel charger
I should still be able to get 50.4 V off the charger on the pack and I can pot down one of my chargers if needed.
