Here is a question for you experts out there! I have four 7 cell lipo packs (25.9v Nominal) at 5Ah each. I have hooked them in series/parallel 2s2p to my bicycle at 51.2v 10Ah. I want to be able to charge it with one charging wire (pos. and neg.) and one balancing 7 pin connector. I want it as simple as possible.
I know I can get a 4-to-1 seven pin balance connector in parallel and use a digital charger to charge up the batteries at 25.9v nominal. The MILLION DOLLAR question is, is there any way to do this while the battery is still plugged into the bike at 51.2v (series)? Can I tap the pos and neg. out of each battery (before the series connector) to make a charge connector (with anderson connectors) separate from each battery's discharge connector (deans plugs), and then put all the batteries in parallel from the charging connectors? So what I will end up doing is plugging in my digital charger and 7 pin connector into the battery to charge all batteries at once at 25.9v, while the batteries are still hooked to the bike at 51.8v... Is this possible??? Please help. Thanks ahead of time to all of you genius's out there!
