titusmc
Hi everyone -
I have a seemingly simple question, but I'm curious about the implications for the rest of the e-bike system.
I have probably 800 or so 18650 cells recovered from discarded laptop packs that I have tested for capacity at 1A discharge using 5 Foxnovo 4S units (20 cells can test simultaneously). My current bike setup is a 48V 1000W front hub motor (eBay generic with silver "rings") run by a grinfineon controller (24-48V, 20A - Model C3620-NC) and Cycle Analyst V3. The battery is currently 13S7P (48V) of recycled laptop cells (all above 2 Ah) and has pretty significant voltage sag under load (5-10V). My performance requirements are very modest - slow acceleration doesn't bother me and I typically cruise at 18-20 mph (400W or so).
My question is the following: When using recycled laptop cells, is it better to build packs with higher voltage (say 20S, 72V) because this will lower the current draw per cell from the pack given the same power and number of parallel cells in each group? My thinking is that as long as I limit the power using the cycle analyst I should get much better battery performance in terms of range because of the lower discharge rate and lower voltage sag. Of course, the obvious alternative is simply more parallel cells, but I also like the idea of lower current through the whole system.
I know I will need the 72 volt grinfineon controller for this, but I've seen threads suggesting that the eBay DD hub motors can take higher voltage well assuming the current is kept in check.
What would happen to the motor and controller efficiency (flats and hills up to 10%) when running this setup limited to 1000W and 20 mph? My thinking is that any drops in efficiency there will be overshadowed by the improvement in battery performance.
Thanks,
ES is awesome!
Thanks,
ES is awesome!
