So I bought a Kelly 8080IPS with sine cosine input. I am trying to use it on the motor in the picture. The motor has a resolver in it. I was told resolver and sine cosine were the same thing, but now I'm being told other wise.
And here is the wiring diagram...
The resistance on the 3 coils is 29 ohm, 29 ohm, 16 ohm.
I was thinking I could take a leg from each coil and connect to ground. Then take the 5V and attach to a leg on the 16 ohm, and take the 2 other legs from the 29 ohm, and 29 ohm and connect that to sine cosine...
Does that work? Any help is appreciated.
Thank you
Eric Ensley
Thank you
Eric Ensley
