I have an EVGlobal 36V ebike. It comes with an LED array for the tail light and a 12V 35 watt H3 automotivde halogen foglight bulb for the headlight. I find that the lights drain the batteries faster than I would like and rob some power. I found a 12V 5 watt MR16 base LED array for track lighting. with the proper base and little cobbling I can get it to physically mount quite nicely in the headlight reflector and housing.
However when I go to turn it on I am blowing the 5 amp fuse for the lights, horn, controller, etc. It is doing this after being on just a few seconds with nothing else running. It is supposed to draw under 500 mA's.
The resistance of this array with my cheap analog meter is about 100K while the original halogen is about 0.5 ohm.
Can anyone shed some light on why this isn't working as it seems like it should to me?
I also checked the resistance of the base with no lamp attached and it was infinite so there is not a short.
Thanks
Thanks
