dumbass
This question is not intended to be another thread about running with or without a BMS.
With that said I have a question for those in the know. I run 8s lifepo4 Thunder Sky 20ah packs without a BMS. I use a CellLog8 attached to a 100db alarm while riding/charging that warns me of a low/high cell or pack. For charging I ether use a 24v 6a lifepo4 smart charger and bulk charge the pack. Or I also have a 9 pin balance plug setup. With the balance plug I use 8 individual (isolated) 3.65v 2a lifepo4 chargers.
The problem is for some crazy reason the packs (2) will not balance even with the individual cell chargers. Don't jump to the conclusion that one of the chargers are bad because I've got 2 sets of 8 charges with the problem. Please remember I am using 9 pins and wires both inside the packs and from the chargers (connecting the positive from one cell/charge to the negative of the next and so on) the same as done for a CellLog8. Any thoughts???
What I would like is to attach 8 of these balance bleeders to my balance plug and use the smart charger to bulk charge the pack. I called the supplier this morning and was told I had to connect each cell to each balancer individually with 2 wires (no jumping from the positive to negative between bleeders). I reminded him the packs were wired in series of 8 cells. He said "that's ok, you still need to wire each cell individually to balancing. So I need 16 tap wires for this? I would think because I am not actually connecting to any power other then the cells being bled I would be able to use just 9 wires/pins just like a CEllLog8. But is this the same problem with the individual chargers?
http://www.batteryspace.com/Balance-Module-for-3.2V-LiFePO4-Battery-Pack.aspx
Bob
Bob
