Whiplash
- Joined
- May 10, 2010
- Messages
- 2,906
liveforphysics said:dogman said:True enough, these days an x5 is no longer even close to cutting edge. Or any hubbie for that matter. The only real advantage of watt limiting as opposed to weight limiting would be not discouraging anybody from entering. It could be all about getting as many guys as possible to pay an entry fee, unless a deep pocket sponsor is found. On the other hand, if running it unlimited draws more folks, do that.
Power limit discourages anyone who is interested in pushing e-bike tech to new levels IMHO.
Whiplash said:I still say let the tires be the limiter, and MAYBE AH of battery, because if you limit the AH to say just barely enough to finish the race safely, you will be limited to how many Watt Hours you can dump into the motor during the race and thus limit the speed/acceleration you can achieve.
The weight limit naturally is a battery limit. Batteries have weight, if you want more batteries, you gotta save weight elsewhere. If you give up some battery capacity, you might save the weight to run the scooter tires with excellent cornering grip, but have to use a lower average power level because of it. Or, if you're running little 700c road bike wheels and tires, you can fit an extra LiPo pack or two on the bike to give you the ability to have more range. etc etc Want suspension? Gotta decide if it's worth trading in the ability to run extra grippy tires? or carry more battery? etc etc.
A weight limit is a natural performance limiter, and a natural way to force the choices in design that make racing and setting up a racing machine so exciting and fun. Keeping the weight limit low essentially means the cost of the battery, controller, motor to be competitive stays decently low. The way I saw it, going from a 70lbs bike to an 80lbs bike, and trying to stay competitive means adding another $500 or so roughly to the bike. Going from 70lbs to 90lbs adds $1,000-1,500 to the bike stay top-tier. Going to 100lbs puts it out the budget I'm willing to spend on an ebike race.
Also, I should add that I plan to win with a brushed hubmotor, and I think my biggest competition will be coming from common off-the-shelf cheap hubmotors. A well chosen $100 roadbike off craigslist + $200 9C hubmotor +$200 controller (tweaked) and $500-750 in LiPo is a recipe to be a serious contender in a bike race at 70lbs, and I think Tiberious plans to fly over here and win with a setup just like that. RC done properly can have a substantial advantage, but it also has it's own share of disadvantages, such as much higher potential for mechanical failures, etc etc.
OK I see your thinking on the weight limit, if we went that route, I say then ONLY do the weight limit, that will make it more of a "run what you brung" type of thing. It is starting to sound fun! I know I will at least be there next year, I don't know if I will be a contender though, since a full suspension off road bike will be a good bit heavier than a stripped down race only bike!
