Hi,
I am currently coding different algorithms concerning controllers and my plan was to add a middle pcb with a processor.
It avoids me to reinvent the wheel as far as controller is involved, while adding my stuff.
I don't know the command/signal/voltage/current my board should send to the different controller connectors.
FYI -on the generic controller- on the corner of the backside, it is written K-S1.5; on the other side, 693689 (whatever it means)... The board is a 200x105mm.
Should it be of any help..
1) Display, purple, is connected to a S+ on my board. What are the different protocols used to send commands / display info on that single wire?
2) Cruise control> {blk:ground}, {white:Q}.
3) anti theft> {Red: vcc}, {orange: A3}, {gray: YB}
4) High low speed> {yellow: K1}, {red: K2}, {blk: gnd}
5) low lvl brake> {blue: SL}, {blk: gnd}
6) throttle> {blk: gnd}, {green: SD}, {orange: 4.3v}
7) high level brake> {gray: SH}
8- reverse> {orange: DC}, {blk: gnd}
The rest is pretty straightforward (power lock...)
So, since we are on ES, i am pretty sure someone will chime in with an idea.
Thanks
Thanks
