Meanwell 35V to 63V charging alternative?
Samd
Ballarat, AU
I was trolling fleabay for 15s meanwells (series combos) when I saw these LED drivers, but text claims they can be used for EV charging.
http://www.ebay.com.au/itm/10-8-35V-to-35-63V-Charger-LED-Driver-Power-DC-Boost-Converter-Constant-Current-/131033744693
Also claims they can be stacked in parallel.
Anyone want to go guinea pig?
Product Description
Feature:
1. Step-up structure, Wide input voltage range (input less than output)
2. Constant current and voltage, Used to drive high power LEDs, and to charge the battery
3. Efficiency as high as 92%
4. Can use 12V/24V battery to charge 36V/48V Battery.
5. Even the Step-up structure breakdown, Will not damage equipment, security design
6. With input reverse and undervoltage protection
7. Aluminum shell potting design, shockproof, Waterproof, Heat-Sink, harsh environments adaptable
8. Pluggable terminal design, easy assembly and disassembly, wiring more convenient
9. Can be Parallel work in power is not enough occasions
More Detail:
Module Properties: non-isolated constant current and voltage can be automatically boost buck
Input Voltage :10.8-35V
Output voltage: 35-63V (adjustable)
Output constant current range :0.5-2.5A (100W MAX) (continuously adjustable)
Output Power: Input 12V, MAX 100W output (input voltage greater than 24V, MAX ouput can reach 150W )
Conversion Efficiency: 92%
Output ripple: 20M bandwidth (for reference)
Operating Temperature: Industrial (-40°c to +85°c) (if ambient temperature exceeds 40 °c, please lower power use, or to enhance heat dissipation), case surface temperature should not exceed 90°c.)
Full load temperature rise: 50°c
No-load current: Typical 20mA
Load regulation: ± 2%
Voltage regulation: ± 0.5%
Dynamic response speed: 5% 200uS
Short circuit protection: No, please pay attention to the short-circuit
Undervoltage protection: about 10.5-11V
Input Reverse Polarity Protection: Yes.
Installation: screw (diameter 3 mm), 2 mounting holes, 2 holes spaced 82mm
Shell: full aluminum
Some Applications
Constant Current output, High Power LED driver
Adjustable Output Car Power
Boost Charger
Power for your electronic equipment
Solar battery charger for electric vehicles
Package Includes:
1x DC/DC Converter
A member here used these
http://www.ebay.com/itm/150W-DC-DC-...y-Boost-Module-Charger-Power-US-/310744421336
and was satisfied.
I got me the 800W version
http://www.ebay.com/itm/281166293173
and am very dissapointed. No way this can deliver 800W, but that's another story.
I recommend to use an open frame version, as these need much cooling.
Search terms I'd recommend
dc dc boost 80V
Even if you need less, use 80V because the caps and parts they use are notoriously overrated.
CC and CV work quite well if you work under 30% of advertised capacity.
