_electricfox_
1 W
Selling here a used MGM controller "TMM 80063-3 X2 Series PROFI" which was only briefly in use.
The controller is fully functional and was operated with a maximum of 13KW peak.
As equipment it has the options: OPTO, SE, BC, WR, FANS
Special feature is the possibility to connect motors with hall sensors, as well as a RS232 connection.
The new price is 2300€.
The exact data of the controller can be found on the Internet.
Additionally offer the following parts for extra charge:
-Y-cable for battery and phases (not on pictures)
-USBCOM 5i: Data communication PC to controller (not on pictures)
-Capacitorbank: Highly recommended to reduce voltage spikes and thus the total failure of the controller.
-ADC to PPM Converter: This can be used to convert an analog signal from e.g. a throttle grip into a PPM signal. The MGM controller can only process one PPM signal as input.
-DCDC Converter (up to 60V, even if 48V is written on the sticker) for the power supply of the fans and the ADC to PPM Converter
-ON/OFF switch
-AVS Precharge Module: This allows you to precharge the capacitors in a controlled manner without creating a spark that destroys the contacts when the battery is plugged in. The original "Precharge" possibility of the controller does not work if an additional capacitor bank is used.
-Miscellaneous cables
Paypal payment possible
Shipping from Germany
-ON/OFF switch
