ElectricGod
Arlo1 said:zombiess said:Arlo1 said:No leboski your numbers are overly optimistic.
Truth is you forgot the sag... Likely a 100v battery will sag to 90v under load.
Also you will never get a 100v fet to survive at its limits with a 100v battery.
The numbers for this would be 84v absolute max fully charged and that will sag to ~75v under load with a good battery.
That gives you 4500watts which is still optimistic....
Who are you and what did you do with Arlo1?
When did you change your tune about how much current a TO-247 device can carry reliably?
Im still here a TO-247 can do amazing current up to the leg limits. But the 4468 can not. You and I both found the 4468 to be limited around 50 rms amps.
I have some bad ass IXYS parts that do better as well some IR igbts in a 247 package that will do leg limts cold and ~100-110 rms when warm.
The 4468 is a fairly robust mosfet. I run a 12 fet controller that has AOT290's in it at 66 volts and 6o amps at my watt meter. That's just shy of 4kw. My phase amps are currently set to 130 amps. The controller warms up to 85F after several miles of hard acceleration at WOT on a 6kw C80100 outrunner motor. If 12 of the AOT290 can do that, why can't 6 of a much stronger mosfet do more than that? Both are 500 watts of heat dissipation, but the 4468 has 2 micro ohm Rds and 200 amps at 10 volts while the AOT-290 is 3.5 micro ohms, 110 amps at 10v. Double the amps and close to half the Rds ought to be worth a good bit more than 4kw in half the mosfets.
I think I said 6kw earlier...that's a typo. I meant 4kw+. I don't know why I said 6kw. I edited that post.
What's your favorite to-247 mosfet?
I looked at the various IXYS mosfets in TO-247 and everything had higher Rds and similar amperage to the IRF4468. I've looked at their mosfets before and was equally non-plussed. What is so "bad ass" about their mosfets?
