zombiess
Tonight I was playing around with a new gate driver I made testing it out which is based on the TD350E chip with a 15A boost stage. I decided to take some random FET samples and see how long it took to fully saturate them with regards to Vgs and 2 different value gate resistors. It has the 2 level turn off feature enabled which lasts for about 600nS and then I have a 3.9 ohm turn off resistor. To get 6.66 ohms I put a 10 ohm and 20 ohm resistor in parallel. I did not bother measuring the drain to source resistance or putting any D-S voltage. This to measure switching time from 0-Vgs only.
I tuned the gate resistors so that there was not any overshoot in the turn on.
IRFB4110 Qg 150nC
10 ohm = 500nS
6.6 ohm = 333nS
IRFB4115 Qg 77nC
10 ohm = 300nS
6.6 ohm = 250nS
IRFP4568 Qg 151nC
10 ohm = 650nS
6.6 ohm = 400nS
IXFK230N207 Qg 1350nC
10 ohm = 1350nS
6.6 ohm = 950nS
IRFB4110 Qg 150nC
10 ohm = 500nS
6.6 ohm = 333nS
IRFB4115 Qg 77nC
10 ohm = 300nS
6.6 ohm = 250nS
IRFP4568 Qg 151nC
10 ohm = 650nS
6.6 ohm = 400nS
10 ohm = 1350nS
6.6 ohm = 950nS
