JRP3
I suppose I could but I'd rather go higher voltage/lower current. Not sure if some of the higher power controllers would even work at 44 volts.
larsb said:Don’t have too large faith in the powervelocity line of controllers, it’s three years and counting since their new controller was announced. I bet they have quite long way to go, especially now with the component shortages.
SlowCo said:Great conversion plans.
Can the battery packs provide the current that the QS motor can handle?
Good find, I guess I'll have to check the welds carefully and check them for signs of high resistance.j bjork said:Edit, here: https://endless-sphere.com/forums/viewtopic.php?f=12&t=116813
These seem to come from a recall because of bad welds:
https://oemdtc.com/7242/22e005-high-voltage-battery-may-fail-samsung-sdi-high-voltage-battery-packs
Some ford seem to use them, as ford was mentioned in the campaign.
JRP3 said:The case looked the same so I assumed they were the same. Are yours Samsung cells?
SlowCo said:You have FoMoCo (Ford Motor Company) cells. As you seem to assume a lot it might be wise to check the actual continuos amp rating. And if you put them in series then the amp and kWh rating don't double.
There is a reference to dyno data here:The Toecutter said:As for the Astros, I was going by a combination of manufacturer's specs and what I've read on this forum. I haven't seen hard dyno data for them.
