Hello everyone, this is dkcomm (Don) once again. This is my second post and I can't get enough of you folks and your expertise! My other post, my first, was to ask a question concerning PWM charging of LiFePo4 batteries (24V, 10AH). Your responses were immediate and excellent! As it turns out my tinkering has produced a bike that has about 10 miles range; a speed of about 18 MPH (Max, level); and, with the flip of a switch, can be driven by an 85 Watt, 24V Solar Panel ALONE (again level Gnd.) The motor is a geared 450 Watt Brushed motor that is quite good on small hills driven by the 24V - 10AH battery. One of my main objectives was to have a PEDELEC (Not strictly electric only), and this configuration has turned out surprizingly well! It is especially satisfying when I get up to crusing speed in bright sun (I live in Florida) and flip the SOLAR ONLY switch! Wow! With minimum input from me the panel drives the motor quite nicely and I sail along on Solar power, i.e., no batt - there is something very exciting about that!
Now, I would like your expert advice once again. I want to use an MPPT type solar charge controller for the battery. Currently (no pun) I use a very inexpensive 12V/24V PWM controller, CMP-xx something. I do need a battery every once in a while... I used a heavy duty (junk) relay to do some switching and the protective Anti-EMF diode across the coil came loose. Since then the CMP-xx has acted quite funny; I think it was zapped. I do not trust it with my expensive LiFePo4 battery, so I want to graduate to Maximum Power Point Tracking (MPPT). I know they are out there in scads but they are expensive and in my case some overkill. (I don't need waterproof, I don't need 30 Amp for example (15 only), etc.)
So, which is the best, inexpensive (very) controller I can get. Best and inexpensive is probably a contradiction in terms but I need something ... Can anyone help?
One last thing. Somehow, somewhere I am going to get a 3-wheel adult bike. My electronics, motor, etc. will be transferred from the existing "normal" bike to the 3 wheeler. I don't have much choice in that; I am 72 and have enough titanium supporting my spine the Russians could build a sub out of it! So, sooner or later, I must get a 3 wheeler. I expect to get similar, perhaps even better results with that configuration. I will have 2 solar panels on it. I was able to secure 2 85 watt 24V (36.5V) panels quite some time ago, but can use only one (and that's a little shakey) at the moment.
Many Thanks Again,
Don
Many Thanks Again,
Don
