el_walto
I was about to sell off my 2009 15Ah 48V Ping V1 battery for cheap to a keener i met on the street, so I took it for a full test ride to make sure it still had an OK amount of capacity.
Tested each cell voltage after fully charge and it was in check.
After Draining 10Ah, a couple cell groups were a little out, but they all seemed a bit above cutoff.
I decided I'd ride it to cutoff to make sure things were working correctly for the newbie buyer. At 13Ah I was getting really suspicious thinking it should be cutting out by now, seemed to be such a low voltage. I decided to keep going until cutoff since i was selling this thing without a Cycle Analyst. Battery never cutoff. At 14.5Ah out of the 2009 battery, I decided to stop and have a look.
I opened the ammo box up to the stinky stench of electrolyte, the sides of the ammo can were bulging. 1 cell group at 0v, another cell group at 1.1volts etc. Some cell groups were fine.
No flames or smoke. Managed to pull battery out of ammo box, cut a bit of tape off and the battery pushed itself apart becoming double the size due to inflated cells. Inflated cells were hot. Not wanting an embarrassing fire in the front yard, I tossed the bad cells in large bucket full of water. Added some salt so they should completely discharge themselves to later be trashed.
This is the second ping battery I've had fail in a month because the LVC did not trip. V1 and V2 BMS. No i don't have a precharge resistor. Did this kill my LVC on my BMS?
I no longer trust these batteries at all, will not store any sort of lithium in my house. Quite possibly could of had flaming bike ammo box if i kept riding for another minute or two.
Will post pictures later today.
