MadRhino
That frame battery box can hold twice as much. That is the good part of it. The bad part of it is poor suspension design, and weigh.
Why do you say it has poor suspension design? The rear shock has a ton of adjustment positions for practically any rear shock. The Head tube will take straight or tapered forks. I will only be riding it on the street, sidewalks...ect no off road dirt tracks.MadRhino said:That frame battery box can hold twice as much. That is the good part of it. The bad part of it is poor suspension design, and weigh.
MadRhino said:The front doesn't matter, you buy the fork that you want and can set steer angle with an angle set kit. The rear has a very primitive swingarm and no matter the shock that you buy, it will have a basic action without any deflection, nor progression. Yet, as you said you will ride on the street, and you will like it if you never knew better.
22 Lbs is 10 too much IMO, and 10 lbs is a lot of effective power loss. You are right talking about power to weight ratio. Now atop of a heavy frame and heavy battery, add motorcycle wheels and tires, a few components on the heavy side to avoid high cost... Then your horse becomes a cow, and she does eat a lot for every mile. :wink:
litespeed said:Yes the frame isn't cutting edge design on rear suspension but it works. It does have tons of room for batteries, wiring and anything else you want to stick in its belly. You won't have a bunch of bags or boxes stuck all over the bike with awkward weight distribution to worry about either.
I would love to have a progressive link suspension on this style bike but don't want to one off a bike. I built a Giant DH and while the rear suspension was better the lack of triangle space forced me to try hanging batteries off the rear....which then wouldn't stand on a kick stand. Then tried the batteries in a box on the front forks.....talk about heavy steering. Back pack wasn't ideal with 24s3p of lipo bricks and always had me feel like I was falling backwards. I won't even get into the drop outs which I got to work using Doc's torque arms but would never compare to these cheap frames clamping dropouts for long term longevity with regen.
For those wanting a good platform to build a hub motor bike these are the best and easiest to build for the average do it yourself-er. Have the ability (fully equipped machine shop or a best friend that has one) to add a battery box to a cutting edge DH bike and devise a clamping dropout system then that would be your best bet. Time-cost-quality are the three things available.....you get to pick two unless your rich.
Back on subject 24s12p from Nkon for,
VTC5 2500mah cells would be about a grand for 30 peak capable amp cells.
Basically the Same price for HG2 3000mah cells that are 20 amp peak.
25R that are 2500 mah would be about $800 ish and are 20 amp peak.
There are a few others but you get the idea.
https://ru.nkon.nl/rechargeable/18650-size.html
Just need to click and buy now. If your were close I'd help you build the pack.
Tom
MadRhino said:On 2 wheels, building safety is in handling and braking first. Second comes proper suspension, for a wheel that had lost contact with the ground on a bump has no traction, handling nor braking anymore. There is a list of safety features I could make, but nothing about weight. Weight is a compromise that you accept to build the features that you consider a priority.
Newagebike said:I have been looking into battery types and I ran across these (link below) Sanyo NCR20700B 4000mAh 15A Flat Top batteries. They are a little bigger but pack in 4000mah which means my 86V 28ah pack @ 24s 7p would only be 168 batteries bring cost to 1,200 with less space used up.
Putting info into the ebike motor simulator, they do not have the QS 205 H50, I used the Clyte TC40100 motor and 20" wheel. It will get me what I want easily. Top speed of 42 with a 28 mile range. At half throttle it goes up to 75 miles and this is all with a 703 max rpm. My QS 205 50H I am thinking of a KV of 17.1 which will bring up the rpm to 1275.
Opinions please.
https://www.imrbatteries.com/sanyo-ncr20700b-4000mah-15a-flat-top-battery/
kingjamez said:My QS205 50H 3.5T (~13KV) in a 17" Moto Wheel on 20S in an EEB frame goes faster than I care to without enabling field weakening. I was worried about the maximum speed and kicked myself for quite a while on only going with a 17" wheel instead of a 19", but now that I've got it running, I personally am not interested in going any faster.
I should have actual MPH numbers shortly, I'm still getting it all finished up, but my test runs have been "exciting".
-Jim
Newagebike said:kingjamez said:My QS205 50H 3.5T (~13KV) in a 17" Moto Wheel on 20S in an EEB frame goes faster than I care to without enabling field weakening. I was worried about the maximum speed and kicked myself for quite a while on only going with a 17" wheel instead of a 19", but now that I've got it running, I personally am not interested in going any faster.
-Jim
How fast do you want the bike to go, what type of torque do you want?
Newagebike said:Those batteries are 15A so that should be tons of amperage? I am looking into controllers could you recommend one? My thinking is that a higher rpm with smaller wheels while be easier on the motor but then there is there Torque/Speed ratio?
kingjamez said:Newagebike said:kingjamez said:My QS205 50H 3.5T (~13KV) in a 17" Moto Wheel on 20S in an EEB frame goes faster than I care to without enabling field weakening. I was worried about the maximum speed and kicked myself for quite a while on only going with a 17" wheel instead of a 19", but now that I've got it running, I personally am not interested in going any faster.
-Jim
Those are kind of ethereal questions.
I want it to go "real" fast, and have "lot's" of torque....
It has enough for me not to want more of either. What I want is likely different from you.
-Jim
MadRhino said:Newagebike said:Those batteries are 15A so that should be tons of amperage? I am looking into controllers could you recommend one? My thinking is that a higher rpm with smaller wheels while be easier on the motor but then there is there Torque/Speed ratio?
10p would let you pull 150A, maybe not too long before they start to heat. Little numbers for a 17 KV motor, that would definitely prefer 15p of those cells. Also, a 17 Kv motor is really happy in a 13" wheel, and the larger the wheel the harder it will be on controllers.
