Hello everyone,
So I'm having problems with my bbs02, it has 2000mi on it and like 2 months ago I completely took it apart because the mostest were blown and I replaced it with the new controller with ifrb3077 mosfets. Then I had the problem, that the motor suddenly stopped spinning. After 3 days I tested again, without doing anything and it worked again, this repeats, but in the same periods..
It can't be the motor overheating (it was cold), the connectors in the motor are connected securely (I know that because I took it apart 3 times to check what it is and I relied on the fact that a connector could be loosen itself, so I crimped them together that this can't be the problem)
And the next time I opened the motor I thanked of that the wires in the controller are loose and there its difficult to do something... I'm not sure iff this is the problem but if it is, do I have to buy a new controller once again??
The throttle can't be the problem since I also have pedal assist and both works until the motor cuts off.
Do you have any tips or ideas what to do?
Thanks very much!
Thanks very much!
