Tom
- Joined
- Aug 2, 2007
- Messages
- 368
Hi guys, great forum. I'm looking to get an ebike to cut off mileage on logging road approaches to backpacking trips here in the Pacific Northwest (many of the logging roads around here have been washed out or gated). I'd rather bike than walk 5-10 miles of logging road each way but the steeper sections really take a toll and I'm wondering if an ebike might be the answer? I've ruled a motorbike out as they would not be legal on gated roads and would also not fit in the back of my SUV. The idea is to drive as far as I can in my SUV and use the bike for the remaining logging road approach.
I'm 175 pounds and would be carrying a 25 pound backpack. I'm in my early 40s and in decent shape and don't mind pedaling - I just don't want my legs to be DOA when I start hiking. Typical bike approach would be 7 miles with 2750' of elevation gain. 3 of those miles might be relatively flat, gaining only 250'. The other 4 miles would gain 2500'. If I did the math right, that would be a 15% grade for the latter 4 milies. The return would be downhill most of the way, so I'm not too worried about that. Edit: Budget would be ~$1500.
Here's a couple of options I'm considering right now with the caveat that I haven't had much time to do a lot of research.
1) Pre-built e-bike with NIMH bateries such as the Giant Lite - I am told this bike has been discontinued but a dealer in town says he can get me one. I have also seen a few online. Cost is $1300. Not sure how much effort it would require on the uphill though or if the battery has adequate capacity for what I plan to do. I suspect it would be a lot easier to pedal than heavier bikes should the batteries run out, particularly on flat sections on the return. A lighter bike would also help save the brakes which might get pretty hot on the downhill.
2) Build my own ala http://ebikeproject.com at similar cost. Advantages would be a much more powerful motor (I think) and more powerful batteries. My biggest concern, however would be the use of SLA batteries which apparently need to be charged immediately after use. I would be dumping the bike in the bushes and then backpacking for several days before coming home to recharge the batteries. So not being able to re-charge immediately after some heavy usage might kill the longevity of the batteries. I suppose I could also go with NIMH or lithium batteries, but the cost seems prohibitive.
Thoughts? Suggestions? Recommendations? Thanks!
