OzTrekker said:..... Appears to be red colored cells in the case.......
Met the man with the distribution. Very charismatic gentlemen and I do empathise with his positive growth and goals for his business. Its nice to see an individual with a true passion, the spark, for ebikes and is selling the product
OzTrekker said:Okay so i purchased a battery from a well known business that shall remain nameless.
It was sold to me as Panasonic cells A grade 14AH 52volt.
There were some problems, the battery failed to arrive.
They stated some shipping problems.
Then they have a new office in Australia.
Then i receive the battery i paid "TOP DOLLAR" for without an invoice.
So then i protest and they email me an invoice.
Good summary and good posts from everyone.. I think its good to have a short easily absorbable assessment of it...Ebikes4Real said:A big capacity, high voltage battery, in a small little case may look great on paper, tick all the boxes to the uninformed masses, and when it's being talked up, but it doesn't count for much, when it's probably good for a 500W kit, but being sold as the perfect battery for a 1000W (or even more powerful) kit. Enthusiasm and BS don't count for Jack when someone actually wants to use that battery at the power levels it is supposedly good for and they find it lacking...
[/quote]TheBeastie said:Frankly, I am sick of folks being overly paranoid about their battery pack. I say we ban this guy and permanently firewall his IP from the server so he can't even merely view it.
JK, hopefully with all the good information shared here maybe will see less of these.
Ebikes4Real said:If you mean the OP, then I don't think he has really done anything particularly wrong here. The only thing that he has done is trust the information he was provided and assumed that the battery would deliver on it's promises. Details currently listed are:
•14ah massive for this size
• 702-watt hours means incredible range in small package (read article on watt hours)
•14s4p = 56 Genuine name brand grade a Panasonic 18650 cells (see breakdown on 18650 cells)
•30amp continuous BMS 60 amp bursts
It isn't really up to the buyer, to understand the detailed specs of what they buy and the components used to construct it. The buyer expects that the battery can reasonably deliver what was promised (52V, 14Ah and 702Whrs, 30A continuous, though not sure where the 702 comes from, as 52*14 is not 702).
JK, hopefully with all the good information shared here maybe will see less of these. [/.quote]
I am not sure who your having a pop at?
I hope it is not me the consumer/customer.
I made a change from lipo to lion - i am a learner.
When I was in HOLLAND the "sales staff" always show you the watt hours clearly marked on the packs they sell! They stress that this watt hour marking on the battery is important to check; and state that this simple marking on the battery is key to any purchasing decision.
The crux of the problem is this - I got confused by the advertising from the seller- in my mind i questioned wether there was a mix up with the batteries and I received the 11amp hour battery instead of the 14ah that i paid for.
If the battery was marked 650- 700wh QC signed off with an insert about how best to charge my new panasonic GA for longevity - then I would have had more confidence as a consumer.
I dont believe in gagging debate. Every post I read on this site adds to my understanding of ebiking, and I value and respect every persons contribution and sharing of knowledge - wether they are electrical engineers, novice enthusiasts, Nikola Tesla worshippers or tyre experts - every person brings something positive to the table by making an effort and posting.
When i run this next test low and slow - i am hoping for 650-700wh, then i will understand how best to use the pack.
As the consumer I need to understand the capability of my battery purchase.
I need to understand "range" and i am learning that this is dependent on many factors - thank you for all your contributions i treasure it.
I now ask myself the question -
What is the task?
How best to approach that task?
Is that task achievable?
This is the journey i want to make tomorrow.
Can my lion battery get me to my destination and back.
So now I am hand-building my own battery so i will then truly understand how it all works.
Knowledge is power.
I only have a few posts, many of you have thousands, so I concede you must have some frustration dealing with a novice like me and I thank-you for your compassion and patience.
How many lithium ion batteries have you hand built and tested Beastie?
What did you learn in the process?
Although you don't tell where in the Netherlands they told you that, it's nothing but correct and something you might expect over here. Watt-hours are generally considered to be the appropriate unit for measuring energy capacity of a battery. Ampere-hours are not a unit of energy at all.OzTrekker said:When I was in HOLLAND the "sales staff" always show you the watt hours clearly marked on the packs they sell! They stress that this watt hour marking on the battery is important to check; and state that this simple marking on the battery is key to any purchasing decision. [...] If the battery was marked 650- 700wh QC signed off with an insert about how best to charge my new panasonic GA for longevity - then I would have had more confidence as a consumer. [...] As the consumer I need to understand the capability of my battery purchase.
No, it's a unit of energy equivalent to 1 Watt of power expended over a period of 1 hour. The SI unit is Joule.Tom Tom said:Ive always assumed watt hour ratings were a best case scenario/max available kind of thing.
johnnyz said:I made a 24s 8p pack from the Panasonic NCR18650b cells, and I have to say I was suprised at a couple of things;
At first I used the normal 98 % nickle strip (see photos) and welded them all, Everything looked good untill I tested it.
HUGE sag even at moderate amperage..at full throttle it would only pull 36 amps on a controller designed to pull 60. Voltage went from 96 to 76.
I took the blue shrink wrap off and got into the cells....well...
The attachment points where each parallel group joined the next got so hot that it melted the duck tape and turned color!!..On the cycle analyst, it showed resistance of .519 ohms...I then added extra metal strip to these areas and put it back together...Better...sag is less, now pulled 43 amps on full throttle and resistance was .430 ohms.
Decided to look into the pack again and although I didnt see any signs of the new tabs soldered over the originals getting hot I decided to add one more strip to each of the parallel groups and again an improvement...down to .335 ohms of resistance on the cycle analyst (compared to .198 on my headway cells) and now it will pull 55 amps, but still sags under full load but sagging under partial load like 10 amps is about 5 volts ...
Can anyone who has experience building packs kick in some advice?...maybe I should used the Sony VTC5, but I would have had to add lot more cells...
Also not getting near 23 watt hours out of the pack...more like 17.
John
Stop using the battery please Where did you buy the cells?are you 100% sure and test the strips are 99% nickel?johnnyz said:I made a 24s 8p pack from the Panasonic NCR18650b cells, and I have to say I was suprised at a couple of things;
John
depends on how meny Ah the compleet battery is and how much Amps the controller takes from the battery.Marin said:johnnyz said:I made a 24s 8p pack from the Panasonic NCR18650b cells, and I have to say I was suprised at a couple of things;
John
only slightly off topic John, but I have a shark pack with the NCRB cells and it sags like mother ( 7 volts on the first hill) with the riding conditions that I have where I live, it seems fine if the riding is totally flat, not a performance cell at all judging by the one I have, pretty disappointing. All my other packs are 25r cells, only way to go for me with the steep and constant hills I deal with.
Use a magnet and test your "nickel" strip. It's probably just steel, maybe with nickel plating. People get shafted by vendors with that stuff sometimes.johnnyz said:Can anyone who has experience building packs kick in some advice?
Where are you reading this value? Are you using the wh/mile? Because lower is better on that one. (and doesnt' have anythign to do with pack capacity)Also not getting near 23 watt hours out of the pack...more like 17.
