Thanks for the 'safe' heat explanation Methods and John. So basically the windings can take a little abuse and I shouldn't worry to much about a weak winding smell at around 90-100c, but more about what spikes I am getting.
I'm running 18s lipo, lyen 18fet set to 60/150a 2.5 block 85% max speed for around 5000w peaks and 4000w constant up steep hills. I realise I can get it a little further looking at the simulator and results here, but i need to work more on my riding style and throttle control off the line 1st. Still having to much fun dragging cars scooters and Lycra wearers.
Will also be investing a temp probe asap.
Arlo I love the fan and wiper pump idea!!
What size are the fans? I may attempt something similar.
I notice that in the images the holes are largely )
For max efficiency I would maybe also consider small shrouds or ducts on the fans to help guide the airflow to where it will naturally go in the wheel (if they fit) and gaskets under the fans. Sealing those gaps does make a difference.
Cant wait for your results!
and my 5404 so ill have a motor to ride on while i attempt projects like this.
