I"m using sketchup with two frames in my head.
The first frame was planned for as a suspension cruiser hence the long wheel base. My quilbix wheelies at a slight touch of throttle, so I wanted a longer wheel base then the quilbix. This mean that I might more room for batteries. I had 8 6s16ah pack on the top half of the the frame, and 4 6s16ah on the bottom section. When I do decide to commute with it, it'll be a 37miles round trip. So I'm cramming 8 6s16ah in the top section and 4 6s16ah in the botttom. With my luck, cramming 8 6s16ah in the top allows me to place the bottom bracket anywhere below the lower batteries compartment.
The second frame looked a bit cleaner. However, side by sides lipo packs measured 6" long. I might need a wider bottom bracket 170mm fat bike or 208mm bottom brackets for the pedals to clear. Center of gravity looks is also a bit better too for cruising hard.
So far both have not had any mid motor accounted for yet. I still haven't decided if I want mid motor or hub motor. But it wouldn't be too hard to modified the frame or the Farfle swing arm for a mid motor. I might just make another swingarm also.
Let me know if you see any thing that's obviously.
don't worry about the 78deg angle. It's the maximum angle if the bottom tube is parallel to the ground. Most likely it'll tilt toward the ground and reducing the angle ~68 to 72 or so.
