Stiffler359
- Joined
- Sep 24, 2020
- Messages
- 14
Hello & thanks in advance for not being too hard on me for my ignorance!
I've been helping a friend of mine out with his ebike company, where I've been focussing on the electrics (I have a pretty good understanding of low voltage because of the industries I've been in) while he focuses on the 'look'. Recently he's asked me to swap out the BMS's on a few of his packs because they are apparently fried, but after disassembling them I've found several damaged (burnt) cells. In an effort to salvage the cells that were not damaged, I completely disassembled the pack.
The packs in question are Calibike 20s4p packs using Model 3 2170 cells. After nearly burning the shop down (use your imagination) I got the cells all separated & measured all of their voltages. 4 of the cells measured slightly negative, 4 of them measured about 3.7 volts, and the rest (well, except for the roman candle) measured 4.28 volts.
I'm now in the process of discharging them all on a bunch of Opus chargers, but before moving any farther I have a few questions:
Isn't 4.28 volts a little on the high side? The packs have been sitting around for months, so they were probably even a little higher voltage before. Could this be why some of the cells fried?
While pulling the cells apart the shrink wrap came off (the cells were all touching in the original pack, and had kinda melted together). If I reuse the cells I will use cell holders, do I need to re-shrink wrap them?
What voltage should the cells be at when I assemble a new pack? What is the process of balancing a new pack?
Thanks!
Thanks!
