MastaKebob
Looking to build my first ebike. Been lurking for a while and think I got the basics. Hoping to get some guidance/validation before purchasing.
Background Info:
Desired max speed on level ground: 20mph on level ground with light pedaling.
Desired range: minimum of 5 miles at 18mph (I live in downtown DC, I plan on using this for 1.5 mile 1way commutes and 2 mile 1-way trips to the store).
Wheel size: 700c
Brakes: Cheapo Caliper brakes (will probably upgrade to dual pivot calipers during conversion)
Rider weight: 190lbs
Terrain: Mostly flat but a few short hills (going up a hilly block or up a parking garage ramp).
Ride Profile: Lots of starts and stops, mostly flat with minimal potholes. I usually get a block or 2 before having to come to a stop. I'm OK sacrificing top speed for speed off of the line and hill climbing ability. 99.9% of rides are on pavement.
Budget: $750
Skill level: Computer Engineer with some wiring and bike maintenance experience. Able to work a zip tie and wrench. Have an LBS on speed dial who can build and true wheels if necessary.
Donor bike:
BikesDirect.com Motobecane Bistro 7v: http://www.bikesdirect.com/products/motobecane/bistro-dlx-7v-city-bikes.htm
Anticipated purchases:
Motor Kit: 48v500w BPM2 kit (available from a variety of vendors, but probably either https://bmsbattery.com/ebike-kit/348-bafang-bpm2-48v500w-rear-driving-bike-conversion-kit-ebike-kit.html or http://www.elifebike.com/peng/iview.asp?KeyID=dtpic-2012-7U-CJNQ.05DJS)
Battery + Controller: 48v11.6ah Panasonic bottle pack with Controller from BMSBattery (https://bmsbattery.com/ebike-battery/680-48v116ah-bottle-09-panasonic-battery-pack-battery.html). Note that it comes with a 20A sine wave controller.
Torque Arms: 2 Rear torque arms to shore up the Al drop outs.
Questions:
1) Is the donor bike capable of safely handling this upgrade?
2) Battery + Controller: I've read (older) posts that don't recommend bottle batteries because of 'voltage sag' due to low C ratings. This particular bottle appears to have sufficient V's, C's, and AH's to drive a 48v500w BPM2. Is this a correct statement? If not, why not? How much performance hit will I take with this battery/controller over a Ping 48v10ah brick?
3) With the battery having a controller built in, can I bin the controller that comes with the Motor kit?
4) How difficult is it to swap out displays/throttles at a later point if I'm unsatisfied with the ones that come in the kit? Are they standardized connection-wise that I could plug and play a new one?
5) What vital thing am I missing?
Thanks in advance! Even if no one responds, this forum has been a huge help already.
Background Info:
Wheel size: 700c
Budget: $750
Donor bike:
Questions:
