4LivesPerGallon
- Joined
- Jul 2, 2015
- Messages
- 305
Nitecore charger charges Soshine 18650 LIFEPO4 to 3.44V resting voltage .. doesn't seems normal .. comments?
I thought that, after a charge, the cells would drop to 3.33V or thereabouts, but it didn't.
The resting voltage was read over a week after charging; and, double-checked with an industrial multimeter.
Should I manually override this charger, and stop at 3.33V? The charge rate is 750ma. (I toggle the mode to LIFEPO4 from LI-ON which is the default setting.)
Nitecore charger:
http://www.amazon.com/Version-NITECORE-i4-Intellicharge-Charger/dp/B005UAI372
Soshine 1800mAh "3.2V protected cell":
http://www.soshine.com.cn/a31.aspx
Nitecore charger:
