1) I have a "standard" RS232/CAN/USB module that I interface so things are set up for what I like to do. By bringing the pins out the way I did, everyone can roll their own interface if they want/need it. You don't need the RS232 for typical "dumb" controller operation. You can add your opto's off board. Remember PCB real estate cost money! I don't like to put "everything" on the board. There are layered economic reasons for doing it this way in the commercial world.
Njay: Well, at least we shouldn't be calling it RS232, because that implies certain voltage levels and negative logic, and someone may end up connecting a real RS232 master on there which isn't healthy. When you do lots of projects with RS232 it makes sense to off-board this interface, but for a one-off as I suppose would be the target for this controller it is not the simplest solution - and I don't like "special cables", but anyways it's just a personal preference.
2) Note from the data sheet on the LM2931:in the TO-263 package, θJA is 73°C/W; If the TO-263 package is used, the thermal resistance can be reduced by increasing the P.C. board copper area thermally connected to the package: Using 0.5 square inches of copper area, θJA is 50°C/W; with 1 square inch of copper area, θJA is 37°C/W; and with 1.6 or more square inches of copper area, θJA is 32°C/
W.
I am sinking to 0.17 sq in of copper. Using your numbers, 0.219 W * 73 °C/W = 16 °C Not a problem! Besides, don't know if this matters, but I have used this regulator many times before...
3) Yes. Think it through to the next level, do the FMEA. This is the more reliable version with respect to shutdown, I believe.
I wasn't seeing it right, the culprit that I wasn't connecting to was "GND to inhibit". So yes, PNP is the choice.
4) Thanks! ... raaats,
![Oops! :oops: :oops:](/sphere/data/assets/smilies/icon_redface.gif)
guess I left in some "special sauce" that's going to get me whacked by the "corporate" Chief Engineer!
Just make sure the PCB traces can handle the current until the user realizes the mistake
Keep 'em coming! Can't believe I used to hate design reviews 30 years ago! :wink:
