mikefish
it has balls:
[youtube]kVPjhmTThPo[/youtube]
i would love to see this on an Ebike
I just bolded in blue a key sticking point against the NuVinci, that I was not aware of before.dumbass said:I put one on one of my my ebikes earlier this summer. It works great with very smoot shifting. I am running it with a small Cyclone 360w motor that drives through the crank sprocket chaining. The one thing I don't like is you can't shift when crank is under load. You need to back off on the crank pressure to shift. But the ratio is always perfect for any situation and you can shift standing still. I used the stock hub sprocket that came with the Nuvinci hub so my top gearing is a lot lower then it was originally. I used to hit 28 MPH with hard peddling. But now I top out at about 23 MPH. Not a major problem because I only trail ride now and I'm better off with the lower end gearing improvement.
Reid Welch said:Q: what is the power transmission efficiency of a good internal geared transmission, v. the Nuvinci, v. a derailleur in good order?
Thank, you, Miles. You are always so concise and such a gentleman,Miles said:Reid Welch said:Q: what is the power transmission efficiency of a good internal geared transmission, v. the Nuvinci, v. a derailleur in good order?
Generally, in order of efficiency (most efficient first):
Derailleur
Hub gear
Hub gear with belt drive
Nu Vinci
Reid Welch said:Q: where can I best find these "figures", not that I doubt at all;
only that, in theory, at least, a derailler running it highest gear would be, (correct me if mistaken?): biggest chainwheel to smallest cluster cog=
chain line way from straight = tangental pull = a loss of power transmission efficiency.
Reid Welch said:Have read, probably at Sheldon's site: that a straight line drive of a single, fixed gear, coaster or not, is, with a good new chain and good new cogs:
about 98% efficient. 2% gets lost as heat.
The "new" cogged belts will reduce that 2% to probably, about one percent (there's still rubber flexure and cord flexure of the belt construction.
Great "real results" reporting; thanks!dumbass said:dumbass said:I put one on one of my my ebikes earlier this summer....(snip)
Reid said:IDEAL: a CVT that works like the NuVinci, but will "shift" under fullest power, automatically, by electronic brain and servo motor, to keep the Cyclone-type motor running at its most efficient (max torque per what) range at all times. That'd be heaven, ten pound rear wheel or not.
Press Release March 16, 2009
NuVinci® CVP Developer Kit Now Available from Fallbrook Technologies Inc.
– Provides vehicle designers with easy, low-cost way to implement NuVinci continuously variable planetary (CVP) drivetrain technology –
(San Diego, Calif., March 16, 2009) – Fallbrook Technologies Inc. (Fallbrook), announced today that its NuVinci CVP Developer Kit is now available for purchase directly from the company.
The NuVinci CVP Developer Kit will be on display – along with examples of how it can be used – at the Taipei International Cycle Show in Taipei, Taiwan March 17-20, 2009. The Fallbrook Technologies booth number is L919a.
The NuVinci CVP Developer Kit helps builders of electric-, gas-, human-powered and hybrid vehicles integrate the NuVinci drivetrain into their designs. The kit includes NuVinci CVP, shift actuator, programmable controller, wiring and mounting hardware. Software tools, design instructions and technical documentation are also included.
The base price of the kit is US$595, plus shipping and handling. To obtain more detailed information and register to receive purchasing instructions, go to http://www.fallbrooktech.com/developerkit.
The kit includes:
NuVinci Continuously Variable Planetary (CVP) Transmission (silver color with 36 spoke holes) Speed Sensor and Integrated Wiring Harness
Electronic Shift Controller with 32-bit Microprocessor (operates on 12-48VDC) NuVinci Desktopâ„¢ Application and USB Connection Cable
Electronic Shift Actuator with integrated Position Encoder
Configuration and Shift Tables can be edited with a general text editor program (such as Notepad)
EVnewbie said:I have a Nexus 7 speed internal hub, it is OK and I didn't break it yet.
He pointed out you need special tools to take the hub apart but he can't get those either. Replace the wheel... I know my Nexus NEEDS to be taken apart and relubed but I can't take it apart. Guess I'll ride it until the bearings destroy the seat or until the dried out grease destroys the gears.
The Shimano Alfine is better than most (bang for buck). The benefits outweigh the weight disadvantages in my view. Stronger wheel, protected from the elements, reliable shifting and wide ratio gearing are a few. The downside is more unsprung weight but in my experience handling isn't affected much on the road. I used a Rohloff rear wheel in MTB Downhill competition and there was a difference in handling for sure. I have a non-suspension cargo bike we developed for postal delivery with a the Shimano Nexus hub and the handling difference is undetectable, and we tried very hard to detect it. They're extremely reliable and after about 6 months the trick is to open it up, pull out the mechanism and wash all the grease out then dunk it in light gear oil, sit to allow the excess to oil run off and then re-install. It's a 10 minute job and you won't believe the performance after that. Repeat every 6 months. Another downside is that it is a bit of a pain to change a tire.
amberwolf said:Just remember for all of you that want to use the NuVinci on an ebike and have it be part of the motorized drivetrain--you'll void the warranty on the hub, if the motor causes damage to it. Since you have no way of proving if it did or did not do the damage, and must take the word of Fallbrook, you'd be stuck even if you knew it was not that if they did choose to not repair it under warranty.
Also remember that it must be used as the rear wheel hub of a bike, and can't be used as a non-wheel transmission somewhere, or again the warranty is void.
I love the concept, and I would love to have one, but unless I can find one used that wouldn't have been warranty-covered anyway, it'll never happen until they change that warranty.
Reid Welch said:Great "real results" reporting; thanks!dumbass said:dumbass said:I put one on one of my my ebikes earlier this summer....(snip)
Say, if you can someday post pictures and or videos, that'd be wonderful.
I'm into pictures, as you know.
Thanks again, and best of ebiking to ya',
r.
Sure, but they knew what I was doing and how I was doing it and what the NuVinci would be doing, and they themselves suggested that I use it, implying that they know it would take it.dumbass said:Like anything else if it's not used as designed intended you risk voiding the warranty.
Since they know where my project blog is (they posted on it!) they would certainly be able to see how it was used since I'd have that up on that blog, even if I didn't tell them. My project isn't exactly unique but it is different enough to stand out too much to "hide in the crowd", so to speak.However, let me tell you what happened to me. I had a problem with my shifter and called service on the phone and told them my problem. They sent me a new set of pre-made shifter cables (this does not come with the original kit) plus a set of tools for the future should I need to remove the freewheel. It was all sent to me no charge including shipping. They didn't even question my purchase date even after I told them I have the "08 model. And lets face it how would they know how you had it mounted on the bike if you didn't tell them?
Yeah, I've read of a lot of uses for them that aren't covered by warranty if the use breaks it. It's fine if the person has that kind of money to throw away in the event of uncovered failure, but that's nearly a month's pay for me. Half a month if I went with one of the shady-seeming deals I see on web searches now and then. There is a good reason I am building this project out of recycled parts, other than the 'green" factor and the challenge of it (which is a lot of fun, usually).One last point on the warranty........Before I installed it with my Cyclone motor kit I emailed them to confirm in would not effect the warranty. They replied in writting it would not. However, I would recommend that everyone do the same thing as the issue will change depending on your selected horse power. But as I have read they are being used with gas powered motors as well that are a lot biigger then I plain on using.
If using Windows, it has Paint that will let you reduce the size, though it isn't as "easy" as some other software.dumbass said:I'll try to get some pics for ya but my laptop crased so I need to reload photo software to reduce the pic size so I can download it and I don't have it on this PC.
amberwolf said:If using Windows, it has Paint that will let you reduce the size, though it isn't as "easy" as some other software.dumbass said:I'll try to get some pics for ya but my laptop crased so I need to reload photo software to reduce the pic size so I can download it and I don't have it on this PC.
Open the image, press Ctrl-W, then type in the same percent reduction you want in both of the top two boxes. Ignore the other two. Press Enter, then use SaveAs and a new name to make a new smaller version of the file (so you don't save over the old one).
amberwolf said:Sure, but they knew what I was doing and how I was doing it and what the NuVinci would be doing, and they themselves suggested that I use it, implying that they know it would take it.dumbass said:Like anything else if it's not used as designed intended you risk voiding the warranty.
The thing is, that even if I had money for all this, I still couldn't use their product, because I intend someday to build a cargo trike for people that don't want or can't afford or don't really need a car for most of their travels and trips. That's going to need a transmission, and I would like to have one that could be controlled by it's computer so that the user never has to shift, that all they do is ride it like a bike but without having to really pedal much because the motor/etc does most of the work for them. Automatic transmissions are popular for good reason, even though they're usually less efficient.
Doing it with gears or chain/sprocket is possible, but not as smooth and not as efficient as a CVT, and using a pulley/belt CVT is going to take more space and have more maintenance issues than the NuVinci should.
So I want to use one in the trikes I'd like to sell, but no one would buy it if I had to tell them that if the transmission fails, it's not covered by warranty, so tough luck on that part. I certainly couldn't ever absorb the cost of them failing if they did. I wouldn't be selling these things for huge profit margins, because the idea is to get them to people that can't afford that much (like me), so I would have very little to fall back on should major parts like that fail.
Short and long of it is that while it's awesomely useful, they shouldn't be encouraging people (which they are) to use it for purposes which they know they won't cover if it does break because of it. And it isn't useful for any commercial venture where it is in the motor's drivetrain, for that reason.
John in CR said:How hot does a NuVinci get when it's motor driven up a long hill, so a lower gearing is used? I was under the impression that they lost about 10% at the top end of gearing, but much more in low gear. If people are putting 2kw into them, then if they're as inefficient as I've been lead to believe, a lot of heat would show up on long hills. If they never get hot, then my interest is heightened.
John
dumbass said:OPPs......I went for a ride this morning with my wife and we came upon a down hill run in the forest preserve that she refused to try because it was so steep there was a sign stating to walk your bike down the hill. It was a nice paved section so I thought want the hell I'll give it a go. As it turned out I had to ride the brakes pretty hard all the way down the winding 1/4 mile long road. That was the fun part........then I had to peddle back up again. I was able to get a xlight head start (maybe 50 to 75 feet) before starting back up it. I ran in my lowest range with full power and peddling my tush as hard as I could. I made it back up with no major problem but I wouldn't want to do that for much longer then the 1/4 mile. It would have been interesting to check the Nuvinci and the motor at that time. I would think if they were going to heat up that would have done it.
