Hey guys, just finished this little javascript app which could be a handy reference for people relacing hub motor wheels:
http://www.ebikes.ca/SpokeCalc.shtml
I've got it currently listing the motors which we have in our shop and can accurately measure (Crystalyte, eZee/BMC, and Nine Continent FH205 series). The results with the the different rim choices cross check with our empirical spoke length 'look-up' table generally within a mm. So it seems pretty sound. Note that the Crystalyte 400 series hubs have two different flavours, the newer style rear motors with the offset flange system has a larger flange diameter and hence shorter spoke length than the original 400 series hub design, which is still used on their front (non disk/drum brake) motors.
I didn't bother implementing separate left and right side spoke measurements for rear wheels, in general just adding 1mm to the left side spokes and shortining the right side by 1mm does the trick for hubs that require dishing.
If anyone here has the measurement specs for other popular hub motors like the Bafang, BionX, etc., then I could add those to the drop-down list as well.
Justin
Justin
