MitchJi
Hi,
If this is feasible it could make a substantial difference for EV comfort and range. For the Model S Consumer Reports states that:
The following is based on a post, a long time ago (I don't remember where but not ES), in which someone stated that he heated his EV with a DeLonghi Oil Filled Radiant Heater, then on his commute to work the stored heat maintained the passenger compartment at a comfortable temperature.
Most or all modern EV's have the ability to preheat or cool the passenger area, while they are connected to the grid. If they heated or cooled something with sufficient thermal mass to use stored heat, to maintain a comfortable temperature for as long as necessary, the space heating would have no impact on the vehicles range. The amount of stored heat, required, would depend on, among other factors, on the range of the car. A fringe benefit would be that radiant heat is a very comfortable type of heat.
What I envision is an insulated box, or boxes with containers filled with either a phase change material which seems like a good match for EV heater use, or something simpler, like oil if that will work well enough.
http://sustainabilityworkshop.autodesk.com/buildings/thermal-mass
Is this Feasible?:
Is it possible, and is the solution affordable, to store sufficient heat to maintain a passenger compartment at a comfortable temperature, in a cold climate, for the time it takes to exhaust the batteries of a Leaf or a Model S? Would it weigh too much? Could the same storage medium be efficiently used for cooling as well as heating? Would it work well enough that OEM's could dispense with their heat pumps and in-seat heaters?
Best Approach?:
Would phase change materials be required or would a simpler approach work well? Roughly how much complexity and cost would phase change materials add to this idea? Would all (or most) of the additional complexity and cost be confined to the design?
When the Leaf was introduced I considered conveying this idea to Nissan, but I don't want it to become proprietary. Now, if it's feasible, I intend to attempt convey this idea to Tesla.
So this idea could make a substantial difference, even in EV's with huge packs.Drawbacks include tight access, restricted visibility, and range limitations in cold weather.
The insulated box(s) would have vents, which could be opened and closed. One way this could be used is that the thermal mass could be heated at night, with the vents closed. In the morning the cabin could heated by opening the vents while it's still connected to the grid (the normal space heating would probably be superfluous). Then the vents would be opened sufficiently to maintain a comfortable temperature for your morning drive, then closed when you arrive at your destination, then opened again in the evening, with hopefully sufficient stored heat to maintain a comfortable temperature for your return home. If necessary fans could be used to extract hot or cold air more rapidly.Phase change materials are a relatively new class of materials, which are used to add thermal mass without adding weight or bulk. They may replace standard wall board, or may be an additional layer in walls or floors. They are relatively rare but quickly increasing in popularity as technologies improve and prices drop.
In addition to compactness and light weight, phase change materials absorb and release their heat at certain temperatures, just as water boils at a certain temperature. This helps occupied spaces stay at the temperature desired, even as heat is flowing in or out of the space.
Is this Feasible?:
Best Approach?:
