ZeroEm
Make sure the TA are rotated in opposite directions as to remove any play in the axel.
It almost does not matter, what field you work in.
Stress riser is a location of stress concentrated to a specific area of a material. Whether it be the metal of an electric motor’s shaft, a bit of solder joining printed circuit board’s power connector or even the glass underneath the surface of a touch screen, all materials have a certain amount of force that they can withstand before they break. Now if you take the amount of force needed to cause damage to a material and apply it evenly across the entire surface you will find that the material can withstand much more than if you concentrate that force to one specific point. Any fracture or bend – really anything that weakens the material – creates what is called a stress riser. This place is one where concentrated stress will propagate resulting in a failure of the material’s structure. Gesrepair.com
