bhutches
I am helping a friend with their Organic Transit ELF that appears to have a blown controller. Background history
is this ELF had no battery so my friend and I built a decent 48 volt battery with a Daly BMS , 2170 lithium cells and it ran great for several months then quit while out on a ride. I checked the battery as good but when its plugged into the ELF's controller, the battery input voltage immediately goes to zero volts. Disconnecting the hub motor made no difference in this power drop. In researching the ELF, found it to have a Kelly Controller. So it looks like I will be replacing this controller. I know that I will have to do some customization of the controller's configuration and was looking for anyone who has the configuration values that would get the controller configured to run this ELF's BLDC that appears to be a sensorless hub motor? Also would anyone have a schematic diagram of the wiring of an ELF? I believe this ELF is an older model and has no Cycle Analyst display or any other display. I would like to consider a different name brand sensorless capable controller also. I was hoping to possibly use a Grin Technology Phaserunner but Grin Technology appears to not be able to build them due to the logic chip shortage and now offers a much more expensive Frankenrunner controller. I was hoping to find a good quality but less expensive controller that would be compatible with the ELF's hub motor that might be more reliable than the Kelly Controller. All thoughts on my post are greatly appreciated.
