After 2000 miles on lead and with Dogmans advice, I bought the Ping v2.5 36v 20ah battery for my we bl-36. I ordered the battery on 9/1 and the post office delivered it on 9/11. Very fast shipping!!!!
Every thing is great, but I do have some questions.
1. What are the leds on the bms telling me? It appears that they all turn on when the charge cycle is done, as once they are all on, the charger light goes from red to green. The leds all stay on, as long as the charger is plugged in to the battery, no blinking (ie balancing???).
2. When the pack is removed from the charger, all the red leds on the bms stay on. I am building a box for the battery, so I did a bunch of test fitting and noticed that the red bms led's started to turn blink on and off, without any charger attached. Is this the balancing or is this just the bms drain on the batteries?????
3. The BMS only gets hot when the leds are on. Only the leds get hot. The battery and the rest of the board is cool to the touch. Is this expected?????
4. What voltage should the charger be putting out, with no battery connected to it?? (this is the 36volt 2.5 amp charger that Mr. Li Ping sent with the kit) I need to know as I would like to check mine (with a calibrated meter) and also, I would like to adjust one of my sla chargers (2.5 amp) to work as a backup or for use at work.
thats about it so far, I have yet to make a test ride, but that should be tonight!!!!!
bob in phx
bob in phx
