AlwaysOn37
- Joined
- May 2, 2017
- Messages
- 1
Hi everybody !
I'm new to this forum, and this is my 1st post.
I'm in the process of building a new ebike (I'm the customer, not the actual builder).
I'm going for:
QSmotor 4kw 273 40H V3 motor (72v, 48-144v optional range)
http://www.cnqsmotor.com/en/article_read/QS Motor 4000W 273 40H V3 E-bike Spoke Hub Motor/260.html
Sabvoton (Sine wave) controller SSC96100
http://www.cnqsmotor.com/en/article...usoidal Programable Motor Controller/537.html
In a vectorebike clone frame.
It's going to a 96v (24s), and 16p setup.
I can build it with a 2900mAh Panasonic NCR18650PF (3C max, 46.4ah\4.4kw pack)
Or,
With a 3400mAh Panasonic NCR18650B (2C max, 54.4ah\5.2kw pack).
The guidelines for this build is maximum long term reliability, preferably with as much range and charging cycles as possible.
Going to use a satiator to charge to 80% max and try not to discharge below 20% pack capacity.
My question is:
Assuming I build it with the 3400mah cells (2C max) cells, I don't want to stress it beyond it's "comfort" (max cycle life expectancy) zone, i.e. 1C.
So, 1C of of a 5.2kw pack is 5.2kw.
The motor is rated for 4kw sustained, and 8kw peak power draw.
If I limit the power draw to 5.2kw (1C) in the controller, can it damage the motor (either short or long term wise) ?
I'm aware this setup will decrease my initial acceleration a bit, but since typical peak power draw usually only lasts for 2-3 seconds at most, it will most probably translate to, say a (roughly) a 11-12 seconds 0-60mph acceleration (instead of 10 seconds).
It's still very fast, and I can live with that compromise.
My main concern is the motor.
I've heard of DC motors that got damaged if they didn't get their full peak wattage...
Anybody here with ACTUAL experience with that kind of limiting setup ?
And\or experience with the above mentioned QS motor ?
I'm going for:
Or,
My question is:
