titusmc
Does anyone know if you can safely draw <500mA of current from the 5V line of the BBSHD shift sensor cable? If this line is common with the display 5V supply, I suspect it may support 500mA since the DPC14 has a USB power port (assuming nothing plugged into this port simultaneously).
I'm hoping to make a custom cable to power my rear light and this seemed like an attractive option since that cable is currently unused on my ebike (I use the right hand ebrake cable for my gearsensor).
