Capo_au
Very true.
While on the topic of basic physics principles I should also bring up something else that bugs me. Traction is not proportional to tire size. If two tiers of different tread widths are placed on the same (perfectly flat) surface with the same weight placed on them (including tier weight) they will produce the same traction. Traction is dependent on weight and on the friction coefficient of the rubber. This is a mistake I see made ofter by seasoned experts in their field.
For anyone who is involved with cars this is very counter intuitive, but have a read of this for more info.
This is something you can prove to your self at home if you really want to cement the concept. Take a flat surface, like a chopping board and place a book on it, spine down so that the book is vertical. Tilt the board until the book slides off. Now if you lay the book flat on the same surface and you have just increased its surface area 10 fold (think wider tier) yet upon tipping the board the book will still slide off at the same angle of tilt. For the same weight book on the same surface the traction is the same regardless of surface area (think tier footprint). This works great when explaining the problem to kids.
Anyway, if you really wanted to maximum acceleration of out the trike it would mean shifting the weight towards the back wheel. This may make it handle like a pig but with out wheel spin the straight line performance could be mind bending.
Alternatively, you could always get creative with a spoiler.
Then you really would get some looks :lol:
-Capo
-Capo
